96 Camaro RS 140k 3800 V6 Automatic
Old Sep 3, 2011 | 10:08 PM
check the fluid level to make sure its not over filled. could it be something else like the pan, if you over tighten the bolts to the pan the gasket will leak, lol, not tight enough will do the same. have to get the surfaces clean and straighten the pan if needed so its not all bent around the holes before installing.
Old Sep 3, 2011 | 10:38 PM
Sometimes the seal become hard over time and they wear grooves in the shaft they are suppost to be sealing. The shafts can be swapped out.
dan1980davis
Mar 25, 2022 07:04 AM
th3fr4nchi5e
Sep 12, 2014 09:26 PM
drunkwgun1
Apr 16, 2014 02:15 PM
fritcr
Jan 29, 2012 02:34 PM
lazybchbum
Sep 20, 2011 07:12 PM
