trouble code help p0300 on a 2000 camaro 3800 automatic
Old Jun 23, 2013 | 10:12 AM
dan1980davis's Avatar
Default trouble code help p0300 on a 2000 camaro 3800 automatic
I have an actron autoscanner plus cp9180 and its popping up with trouble code p0300
Abslt tps% 52.5
Engine speed rpm 3340
Calc load % 52.5
Maf flow gr/se. 92.03
Map kpa. 96
Coolant degree f. 154
St ftrm1 % 19.5
Lt ftrm1 % 19.5
St ftrm2 % 4.6
Lt ftrm2 % 19.5
St ftrm3 % 93.7
Lt ftrm3 % -7.5
Lt ftrm4 % -1.0
St ftrm4 % 5.4
Veh speed mph 42
Fuel system 1 closed
Fuel system 2 closed
I don't really understand this so I was looking for some help just replaced motor with known good engine 3.8 new wires plugs fuel filter cam sensor new maf sensor. This is a 2000 camaro rs automatic. For some reason the evap and catalyst monitor won't ok.
Old Jun 23, 2013 | 11:49 AM
fbodyrs96's Avatar
p0300 is random misfire, could be a number of things, plugs, wires, coils, injectors. Just start with the simply stuff first..
Old Jun 23, 2013 | 12:39 PM
Just had the icm checked 5 times its good
Replaced plugs
Replaced wires
Replaced fuel filter
Replaced cam sensor
Replaced maf sensor
Tested fuel pressure k/o e/o 50 lbs then dropped to 40 after pump stopped
Fuel gauge doesn't work
I was wondering if the fuel trim on the freeze data is normal
Old Jun 23, 2013 | 03:16 PM
frumpy's Avatar
Talking
Maybe make a sticky if it isn't already??
OBD II Trouble Codes
DTC Description
P0100 Mass Air Flow (MAF) insufficient signal activity
P0101 Mass Air Flow (MAF) system performance
P0102 Mass Air Flow (MAF) sensor circuit low frequency
P0103 Mass Air Flow (MAF) sensor circuit high frequency
P0106 Manifold Absolute Pressure (MAP) system performance
P0107 Manifold Absolute Pressure (MAP) sensor circuit low voltage
P0108 Manifold Absolute Pressure (MAP) sensor circuit high voltage
P0112 Intake Air Temperature (IAT) sensor circuit low voltage
P0113 Intake Air Temperature (IAT) sensor circuit high voltage
P0117 Engine Coolant Temperature (ECT) sensor circuit low voltage
P0118 Engine Coolant Temperature (ECT) sensor circuit high voltage
P0121 Throttle Position (TP) sensor circuit insufficient signal activity
P0122 Throttle Position (TP) sensor circuit low voltage
P0123 Throttle Position (TP) sensor circuit high voltage
P0125 Engine Coolant Temperature (ECT) excessive time to closed loop
P0131 Heated Oxygen Sensor (HO2S) circuit low voltage Bank 1 Sensor 1 Bank 1 = LH or driver's side
P0132 Heated Oxygen Sensor (HO2S) circuit high voltage Bank 1 Sensor 1 Bank 2 = RH or passenger's side
P0133 Heated Oxygen Sensor (HO2S) slow response Bank 1 Sensor 1 Sensor 1 = before cat
P0134 Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 1 Sensor 1 Sensor 2 = after cat
P0135 Heated Oxygen Sensor (HO2S) heater circuit Bank 1 Sensor 1
P0137 Heated Oxygen Sensor (HO2S) circuit low voltage Bank 1 Sensor 2
P0138 Heated Oxygen Sensor (HO2S) circuit high voltage Bank 1 Sensor 2
P0140 Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 1 Sensor 2
P0141 Heated Oxygen Sensor (HO2S) heater circuit Bank 1 Sensor 2
P0151 Heated Oxygen Sensor (HO2S) circuit low voltage Bank 2 Sensor 1
P0152 Heated Oxygen Sensor (HO2S) circuit high voltage Bank 2 Sensor 1
P0153 Heated Oxygen Sensor (HO2S) slow response Bank 2 Sensor 1
P0154 Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 2 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) heater circuit Bank 2 Sensor 1
P0157 Heated Oxygen Sensor (HO2S) circuit low voltage Bank 2 Sensor 2
P0158 Heated Oxygen Sensor (HO2S) circuit high voltage Bank 2 Sensor 2
P0160 Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 2 Sensor 2
P0161 Heated Oxygen Sensor (HO2S) heater circuit Bank 2 Sensor 2
P0171 Fuel trim system lean Bank 1
P0172 Fuel trim system rich Bank 1
P0174 Fuel trim system lean Bank 2
P0175 Fuel trim system rich Bank 2
P0200 Injector control circuit
P0300 Engine misfire detected
P0323 Distributor Ignition (DI) low resolution circuit intermittent
P0325 Knock Sensor (KM) module circuit
P0332 Knock Sensor (KS) circuit high/low voltage
P0335 Crankshaft Position (CKP) sensor circuit
P0336 Crankshaft Position (CKP) sensor circuit performance
P0372 Distributor Ignition (DI) high resolution circuit
P0400 Exhaust Gas Recirculation (EGR) system
P0403 Exhaust Gas Recirculation (EGR) solenoid control circuit
P0410 Secondary Air Injection (AIR) system
P0412 Secondary Air Injection (AIR) system control circuit
P0420 Three Way Catalytic Converter (TWC) system low efficiency Bank 1
P0430 Three Way Catalytic Converter (TWC) system low efficiency Bank 2
P0441 Evaporative Emissions (EVAP) system no flow (during purge)
P0443 Evaporative Emissions (EVAP) purge solenoid control circuit
P0500 Vehicle Speed Sensor (VSS) circuit (manual transmission only)
P0506 Idle system low/Idle Air Control (IAC) valve responding
P0507 Idle system high/Idle Air Control (IAC) valve responding
P0530 A/C refrigerant pressure sensor circuit
P0531 A/C refrigerant pressure sensor circuit performance
P0562 System voltage low
P0563 System voltage high
P0601 PCM memory
P0602 PCM not programmed
P1107 Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
P1111 Intake Air Temperature (IAT) sensor circuit intermittent high voltage
P0112 Intake Air Temperature (IAT) sensor circuit intermittent low voltage
P0114 Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
P0115 Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
P1121 Throttle Position (TP) sensor circuit intermittent high voltage
P1122 Throttle Position (TP) sensor circuit intermittent low voltage
P1133 Heated Oxygen Sensor (HO2S) insufficient switching Bank 1 sensor 1
P1134 Heated Oxygen Sensor (HO2S) transition time ratio Bank 1 sensor 1
P1153 Heated Oxygen Sensor (HO2S) insufficient switching Bank 2 sensor 1
P1154 Heated Oxygen Sensor (HO2S) transition time ratio Bank 2 sensor 1
P1171 Fuel system lean during acceleration
P1222 Injector control circuit intermittent
P1351 Ignition Control (IC) circuit high voltage (open circuit)
P1361 Ignition Control (IC) circuit high voltage (shorted or grounded circuit)
P1371 Distributor Ignition (DI) low resolution circuit
P1380 EB(T)CM DTC detected-rough road data unusable
P1381 Misfire detected-no EB(T)CM/PCM serial data
P1415 Secondary Air Injection (AIR) system Bank 1
P1416 Secondary Air Injection (AIR) system Bank 2
P1441 Evaporative Emissions (EVAP) system flow during non-purge
P1506 Idle Air Control (IAC) system low RPM
P1509 Idle Air Control (IAC) system high RPM
P1532 A/C Evaporator Temperature sensor circuit low voltage
P1533 A/C Evaporator Temperature sensor circuit high voltage
P1539 A/C clutch status circuit high voltage
P1543 A/C system performance
P1545 A/C clutch relay control circuit
P1546 A/C clutch status circuit low voltage
P1572 Traction Control System (ASR/TCS) active circuit low voltage too long
P1626 Theft deterrent system fuel enable circuit
P1641 Fan Control (FC) relay 1 control circuit
P1642 Fan Control (FC) relay 2 and 3 control circuit
P1643 Engine speed (RPM) output circuit
P1652 Vehicle Speed Sensor (VSS) output circuit
P1657 Skip shift/One to four upshift system control circuit
P1661 Malfunction Indicator Lamp (MIL) control circuit
P1664 Skip shift/One to four upshift upshift lamp control circuit
P1667 Reverse inhibit solenoid control circuit
P1669 ABS Unit Expected
P1670 Driver 4
P1671 Driver 4 Line 1
P1672 Low Engine Oil Level Lamp Control Circuit
P1673 Engine Hot Lamp Control Circuit
P1674 Tachometer Control Circuit
P1675 EVAP Vent Solenoid Control Circuit
p1676 Driver 4 Line 6
P1677 Driver 4 Line 7
P1680 Driver 5
P1681 Driver 5 Line 1
P1682 Driver 5 Line 2
P1683 Driver 5 Line 3
P1684 Driver 5 Line 4
P1685 Driver 5 Line 5
P1686 Driver 5 Line 6
P1687 Driver 5 Line 7
p1689 Delivered Torque Circuit Fault
P1690 ECM Loop Overrun
P1691 Coolant Gage Circuit Low Voltage
P1692 Coolant Gage Circuit High Voltage
P1693 Tachometer Circuit Low Voltage
P1694 Tachometer Circuit High Voltage
P1695 Remote Keyless Entry Circuit Low
P1696 Remote Keyless Entry Voltage High
P1700 Transmission Control Module (TCM) Requested MIL Illumination
P1701 Trans. MIL Request Circuit
P1705 P/N Signal Output Circuit
P1740 Torque Reduction Signal Circuit
P1743 TP Signal from ECM
P1760 TCM Supply Voltage Interrupted
P1779 Engine Torque Delivered to TCM Signal
P1780 Park/Neutral Position [PNP] Switch Circuit
P1781 Engine Torque Signal Circuit
P1790 Transmission Control Module Checksum
P1791 Transmission Control Module Loop
P1792 Transmission Control Module Reprogrammable Memory
P1792 ECM to TCM Engine Coolant Signal
P1793 Transmission Control Module Stack Overrun
P1795 CAN Bus - Throttle Body Position
p1800 TCM Power Relay Control Circuit
P1801 Performance Selector Switch Failure
P1804 Ground Control Relay
P1810 TFP Valve Position Switch Circuit
P1811 Maximum Adapt and Long Shift
P1812 Transmission Over Temperature Condition
P1813 Torque Control
P1814 Torque Converter Overstressed
P1815 Transmission Range Switch - Start In Wrong Range
P1816 TFP Valve Position Sw. - Park/Neu. With Drive Ratio
P1817 TFP Valve Position Sw. - Reverse With Drive Ratio
P1818 TFP Valve Position Sw. - Drive Without Drive Ratio
P1819 Internal Mode Switch - No Start\Wrong Range
P1820 Internal Mode Switch Circuit A Low
P1822 Internal Mode Switch Circuit B High
p1823 Internal Mode Switch Circuit P Low
P1825 Internal Mode Switch - Invalid Range
P1826 Internal Mode Switch Circuit C - High
P1831 PC Solenoid Power Circuit - Low Voltage
P1833 A/T Solenoids Power Circuit - Low Voltage
P1835 Kick-Down Switch Circuit
P1836 Kick-Down Switch Failed Open
P1837 Kick-Down Switch Failed Short
P1842 1-2 Shift Solenoid Circuit Low Voltage
P1843 1-2 Shift Solenoid Circuit High Voltage
P1844 Torque Reduction Signal Circuit Desired By TCM
P1845 2-3 Shift Solenoid Circuit Low Voltage
P1847 2-3 Shift Solenoid Circuit High Voltage
P1850 Brake Band Apply Solenoid Circuit
p1851 Brake Band Apply Solenoid Performance
P1852 Brake Band Apply SolenoidLow Voltage
P1853 Brake Band Apply Solenoid High Voltage
P1860 TCC PWM Solenoid Circuit Electrical
P1864 Torque Converter Clutch Circuit
P1868 Transmission Fluid Life
P1870 Transmission Component Slipping
P1871 Undefined Gear Ratio
P1873 TCC Stator Temp. Switch Circuit Low
P1874 TCC Stator Temp. Switch Circuit High
P1875 4WD Low Switch Circuit Electrical
P1884 TCC Enable/Shift Light Circuit
P1886 Shift Timing Solenoid
P1887 TCC Release Switch Circuit
P1890 ECM Data Input Circuit
P1890 Throttle Position Signal Input
P1891 Throttle Position Sensor PWM Signal Low
P1892 Throttle Position Sensor PWM Signal High
P1893 Engine Torque Signal Low Voltage
P1894 Engine Torque Signal High Voltage
P1895 TCM to ECM Torque Reduction Circuit
Old Jun 24, 2013 | 01:13 PM
|m()d's Avatar
Replaced plugs
Replaced wires
Replaced cam sensor
Replaced maf sensor
did you check compression?
Old Jun 24, 2013 | 06:04 PM
Massey's Avatar
P0300 is a code that calls out a random missfire in ALL cylinders. If this is the ONLY code then it is rarely ignition related, it is usually fuel related. Check fuel pressure, Your fuel filter, run some quality injector cleaner in the tank for a few tankfulls (I recomend the 32Oz bottle of Lucas Fuel system Cleaner (it gives 6 or 7 treatments for the price of 2 of the smaller bottles)). Also check out your air cleaner.
Now if the data you gave was the freeze frame data when the code was thrown then I would also consider your o2 sensors as the trims were a little off from one side to the other. If your scanner does live data then take a look at the O2 data at idle and again at 2K RPM and make sure that both sides are pretty close. The odd reading could have been caused by the misfires.
Massey
Old Jun 24, 2013 | 07:46 PM
Yes that was freeze frame data I replaced the fuel filter and I did run some Lucas cleaner through it I haven't checked the compression because I don't have a compression tester I had the fuel pressure tested with the engine off it went to 50 then dropped to 40 when the pump stopped
Old Jun 24, 2013 | 09:14 PM
Massey's Avatar
what is the FP when the engine is running at idle and about 2K?
Massey
Old Jun 24, 2013 | 09:40 PM
I'll have to find out tomorrow after work but the car runs fine when its parked and rev the engine it only happens when I'm driving mainly anything above 2500 rpm
Old Mar 25, 2022 | 12:40 AM
C note's Avatar
Default 3 pack of coils $28 on amazon problem solved
DTC Description
P0601 PCM memory
P1670 Driver 4
P1680 Driver 5
replace coils
