major popping from passenger side front end?
Old Jan 23, 2013 | 08:41 PM
94camaro11's Avatar
Default major popping from passenger side front end?
When on the road, even when NOT turning, i have extreme popping from my passenger side front tire. I han feel it jump across the frame at my feet. It started as a squeaking but has gotten worse.. Any help?
Old Jan 23, 2013 | 09:44 PM
Could be the wheel bearing hub is shot, or the brakes are disintegrating. Jack the right wheel off the ground and do some tugging, turning and visual inspecting before driving it any further. Check both sides while you're at it.
Old Jan 23, 2013 | 10:00 PM
jkeaton's Avatar
Ball joint....tie rod...control arm bushing...brake calipers...wheel bearing...gotta jack it up and do what camaro69 says....
Old Jan 24, 2013 | 09:41 PM
Noises from the front end could be a very bad thing, and if you are not familiar with how things in the front end should be, you need to have a front end shop check things out before you wind up shaking hands with a tree.
AmericanMuscle1989
Oct 17, 2013 07:51 PM
AmericanMuscle1989
Aug 22, 2013 08:25 AM
tjsmar
Jun 10, 2011 01:45 PM
tirocz
82-92 V8 Tech
Mar 25, 2008 05:38 AM
doinbout150
Oct 8, 2007 09:32 PM
