What is this?
Old Oct 3, 2012 | 09:01 AM
jkeaton's Avatar
Default What is this?
On the backside of the front lower control arm. Kinda looks like a ball joint, but hard to tell. Is it bad that I can see the shiny part?
It's like this on both sides.
Old Oct 3, 2012 | 10:38 AM
BasicConcepts's Avatar
Technical User
Looks like a lower control arm bushing is a little chewed up. There a real pita to replace may want a shop to do it... unless you have a press.
Old Oct 3, 2012 | 02:19 PM
yep looks really lose or worn. look here to make sure its the rear bushing we are lookin at. http://performanceworks1.com/PDF%20F...s%20Manual.pdf
Old Oct 3, 2012 | 03:06 PM
jkeaton's Avatar
Better to just replace the whole control arm? (even though I just got new ball joints)
Old Oct 3, 2012 | 04:19 PM
Technical User
it will be cheaper to just replace the bushings. you could always go tubular control arms, but those run about 600$
Old Oct 3, 2012 | 06:05 PM
MKCoconuts's Avatar
Moog lower bushings are only like $30 bucks for a set. Which is better than the uppers which are $30 for one...
Old Oct 31, 2012 | 07:11 PM
libertyforall1776's Avatar
Those need replacing! I had mine done under an extended warranty -- I hear they're a pain to do! The dealership just replaced the entire A Arm which came with new bushings... It was amazing how much of a difference the changed bushings made in how the front end feels!
Old Oct 31, 2012 | 11:35 PM
Chaotic94's Avatar
September 2011 ROTM
I did my own with a big c-clamp. I won't lie, it took a couple hours to do both sides but totally worth doing it yourself if you have the resources! Saves quite a bit of money. Lol
Old Nov 1, 2012 | 07:43 AM
jkeaton's Avatar
Remove control arm? Press the old one out with a c-clamp and press a new one in? Probably the most time spent on removing the a-arm? Silly, easy question, how do I tell what suspension option I have? There are different bushings, I guess, depending on the suspension. F41?
Old Nov 1, 2012 | 09:57 AM
Chaotic94's Avatar
September 2011 ROTM
Codes in the glovebox will determine your suspension package. What I did was get a c clamp that you screw the big bolt through to tighten more and more. If that makes since. I put the c part of the clamp in a vise and screwed the big bolt with a 4 way. I don't know how else to explain it other than draw a picture and upload it lol.
