leaning to the right.
Old Jun 25, 2012 | 06:40 PM
Oh yeah, almost forgot. A good portion of your exhaust system, including the cat converter is also hanging on the passenger side. It's no wonder the right side hangs just a little lower than the left from the factory.
Old Jun 25, 2012 | 08:29 PM
woodstock's Avatar
yeah the 55 has been taking up the lift latley havent had a chance to look under.
i did take some measurements awhile back, I think i did the opposite corners of the engine bay, and like the rocker panels. it was off..
i should remeasure and post some numbers. (scary)
I have never herd of the stock un-level stance. I feel like that is something i would have noticed from day 1.
Pictures arent on here for some reason il try again..
Old Jun 25, 2012 | 08:34 PM
woodstock's Avatar
i suppose all that would add up. maybe il do some research.
and the pictures are in the album "camaro rebuild" or something like that
Old Jun 29, 2012 | 11:22 PM
305_camaro's Avatar
March 2012 Ride of the Month
I know the solution, just put taller sidewall tires on the passenger side!
Old Jun 30, 2012 | 10:55 AM
woodstock's Avatar
haha. with larger diameter tires on one side i think it would pull to that side wouldn't it? more tire to turn on one side ya know
Old Jun 30, 2012 | 10:56 AM
woodstock's Avatar
by the way i didnt see anything wrong bent or broken when i looked. strange..
Old Jun 30, 2012 | 11:09 AM
Not in the front, as the tires aren't drive tires. Wouldn't pull if in the back either, the differential compensates for those differences.
Old Jun 30, 2012 | 08:49 PM
305_camaro's Avatar
I was meaning it wouldnt look like its leaning as much
Old Jul 1, 2012 | 06:29 PM
woodstock's Avatar
yeah well thats an idea, that would 100% work.
its a possibility if i ever get it running right, no sense in looking good if it doesn't run good!
Old Jul 5, 2012 | 01:47 PM
  #20
vanquishfist's Avatar
Mine leans, my friend's leans, most others I see lean. The car is just trying to act cool.
ZACK777
May 20, 2011 10:35 PM
maudyZ28
Mar 24, 2010 08:53 AM
Vidman
Jul 23, 2009 04:40 PM
fonjo
Feb 24, 2007 09:01 PM
zmanps69cam
Jan 9, 2007 12:34 AM
