2000 SS leaning
Old May 18, 2011 | 08:21 PM
ZACK777's Avatar
Default 2000 SS leaning
I recently bought a 2000 SS convertible. I noticed today while walking up to my car that it sits lower on the passenger side, Most noticeably in the rear. Does anyone know what would cause this? Maybe a bad shock or spring? Hopefully nothing is bent... I will try to get pictures up tomorrow. Thanks for any help guys.
Old May 18, 2011 | 08:46 PM
Phalen123's Avatar
It could be springs but believe it or not these cars actually designed like that so they sit level with a driver in the seat
Old May 19, 2011 | 12:38 AM
libertyforall1776's Avatar
Some say that is just how it is and there is variance among cars -- there was a similar thread on this in the Suspension & Brakes section on LS1Tech.com What shocks are on the car and how many miles?
OEM de Carbon/Delphi shocks are the weakest link in 4th Gen suspension -- consider changing them -- SLP Bilsteins, or Koni SAs if you want to lower or can afford the best.
It is also possible if you have or once had a disconnected or blown shock before you bought it that the spring on that side could have unusual wear compared to what would be expected normally.
Old May 19, 2011 | 01:48 AM
the only way i noticed it was when i measured from the floor to the fenderwell while ordering parts from strano's. he mentioned that it is thought that gm did design the 4th gen camaro to set level with a driver. if its true or not may never be known for certain.
Old May 19, 2011 | 10:34 AM
vanquishfist's Avatar
I just changed shocks and springs and my car is still lower on the passenger side. I figured it might have been to compensate for the driver.
Old May 19, 2011 | 12:13 PM
Adam9066's Avatar
i could be wrong but i have a hard time believing that gm designed it that way. I would imagine its just years of use and probably the chassy wants to twist that way when you get on it.
shocks shouldn't play any roll in the ride height there only purpose is to dampen impacts and the springs. again shouldn't doesn't always mean does.
also usually there is a rubber bushing or donut that the springs sit in. sometimes those can break down or they get twisted and the spring isnt siting in them right.
Old May 19, 2011 | 12:42 PM
its in the design, all 4th gen camaro's lean to the passenger side. some to different degrees.
Old May 19, 2011 | 01:28 PM
Adam9066's Avatar
mine doesnt. they may all possibly lean but the newest 4thgen is at least 9 years old. i question if its just not wear and tear from the age. i mean look at all the old older large luxury cars they used to have the springs wear out and they would sag in the rear. hell when i took the rear spring out of the 69 vette it was almost flat.
my car doesnt lean like i said but i also replaced all my springs and the bushing the springs sat in and my shocks and struts or maybe im just lucky or maybe its so slight that i cant see it. Though i catch almost every abnormality in my car. but like i said parts wear out with age especial when a cars like these that are run hard and there age.
Old May 19, 2011 | 04:03 PM
I saw a mint fourth gen SS pulling out of a car show one time which looked babied and probably had low miles that leaned on the passenger side.
Old May 19, 2011 | 09:42 PM
auto's Avatar
strange... mine doesnt lean, maybe the impact straightend it
