Driveline noise
Old Nov 22, 2012 | 01:41 PM
nagysauto's Avatar
Default Driveline noise
2002SS aniversary ,11000 miles has chattering noise on decel. Clutch in no noise, all new bearings when changing from 3.42 to 4.11 same noise. torque arm tight ,trans mount good,on throttle no noise,coast or decel noise, clutch in no noise. Was told these cars transfer alot of driveline noise? any suggestions? Thanks Larry
Old Nov 22, 2012 | 02:00 PM
look for any cables or such that could be rubbing the driveshaft. the rearend will move up and down a little with throttle up or down. any indication of where its coming from, location
Old Nov 22, 2012 | 08:10 PM
nagysauto's Avatar
it is not a rubbing type noise, it sounds like spider gear chatter on a worn out open diff.
Old Nov 22, 2012 | 10:34 PM
sounds like a throw out bearing. maybe a dry universal joint. better check the brakes and make sure they are not dry, need to have anti chatter grease on the backside of the pads, thats all i can think of.
Old Nov 23, 2012 | 11:06 AM
nagysauto's Avatar
Thanks but none of the above Larry
Old Nov 23, 2012 | 01:06 PM
Cheeks's Avatar
August 2011 ROTM
what was the backlash set at on the rear end? how did the pattern look on the coast side? Sounds like maybe its off a bit
Old Nov 25, 2012 | 05:02 PM
nagysauto's Avatar
It did it with old gear and new gear Thanks Larry
camaroguy86
Mar 7, 2013 07:34 PM
milkinit
Nov 20, 2011 02:21 PM
milkinit
Aug 16, 2011 09:17 PM
89cam
Jun 2, 2011 08:30 PM
Kopack2007
Apr 22, 2011 12:07 AM
