Stealth Bomber
#33
Has anyone used the Lakewood Driveshaft Safety Loop before? I am looking for a good one and noticed it was fairly cheap. It is flat steel, bolt-on, part # 18022.
Am I better off getting a different one? UMI? BMR?
#34
you can get the driveshaft loop on the crossmember mounted torque bar.
i have a straight crossbar in it now, i was hitting everything on the one with the wow in it to clear aftermarket exhaust. kooks tucks in so good it doesnt need it.
#36
Socom, whats your opinion of the short torque arms? I just feel like those mounting points were never designed to take that much load... I would only do it if I changed to 3 pt SFC's Im thinking. Im not against it, but just curious/paranoid.
I currently have factory manifolds to the Magnaflow y-pipe and the Flowmaster C/B and it rubs the stock tunnel brace....
#37
#38
Sounds good to me then, I noticed the BMR set up is like $420, so thats not too bad.
I guess if it can take launches like that it'll be fine for my car.
#39
Well I received my new park/marker lenses today, they are a black back ground, but not smoked... so I guess I will have to smoke them myself and hope they dont turn out too dark, wish me luck.
#40
If you're gonna use niteshade spray just do like 2 light coats and it won't be dark. When I had mine I went too much probably like 4 coats but was still able to see lights and blinkers during the day and night time was no problem.
Goodluck.
Goodluck.
