new speakers in car.
Old May 10, 2012 | 09:52 PM
94ChevyCamaroV6's Avatar
Default new speakers in car.
In a 1994 camaro v6 with bose stereo i was told in order to use new speakers i would have to rewire the whole car speakers to the headunit because the bose amp wouldnt be able to be used. is it true that i would have to rewire all the speakers to the wiring harness with a different radio.
Old May 10, 2012 | 10:03 PM
BasicConcepts's Avatar
Technical User
no theres 2 wires that go to the amps there the speaker wire you can cut the amps out and wire up to those wires just gotta figure out which wires are which
Old May 10, 2012 | 10:10 PM
cut the wires off the amp and run those to the head unit? how would i know which of the four to hook onto the wiring adapter.
Old May 10, 2012 | 10:59 PM
MKCoconuts's Avatar
To make this easier, pretend (or actually do) sit in front of where one of your speakers would be. The door one's are the easiest so I'd go with that. If you take the stock speaker out, there should be a connector with four wires to the mini-amp that's on it. Cut it. Pick two wires from the bunch (it doesn't matter which two, I've tried all combinations and all sounded and worked the same). Wire them to your aftermarket speaker and put everything back together. Add in your aftermarket head unit and bam, you're done.
Patrick Quentin Musick
Mar 17, 2013 06:50 PM
charlie94
Oct 30, 2011 12:35 AM
The Banks
Apr 12, 2008 01:36 AM
ctboy
Nov 10, 2007 08:07 AM
97camaro
Sep 11, 2005 05:48 PM
