Lt1 swapped my v6 camaro can’t bypass vats
Base on that page it would, heck of a lot less work.
You are using the 94 PCM? I just remember there is an issue with swapping 94 and 95 transmission. because of different wiring. So using the 95 PCM would require the 94 trans to be rewired.
