any one use the bakerselectronicx VATS bypass
Old Mar 3, 2011 | 08:32 PM
Graphite07's Avatar
Default any one use the bakerselectronicx VATS bypass
if so where did you find the wire to hook it up? it says i need to wire into the VATS Fuel Enable Circuit 229. i could not see this under my dash any help.
Old Mar 8, 2011 | 09:38 AM
1989_RALLYSPORT's Avatar
they really sell vats bypass?
all you gotta do is measure resistor chip in key then get appropriate resistors and hard wire them between the two orange wires in your column an presto you can use any steel gm key instead of a vats key
Old Mar 9, 2011 | 04:58 AM
Graphite07's Avatar
i tried that.. it was a no go.. my key is a 14 and i did what i found on the net it was a no go.
TNDawg123
Feb 26, 2018 12:05 AM
GlennD
May 3, 2013 09:38 PM
randyf
Aug 17, 2010 09:23 PM
randyf
Aug 14, 2010 08:27 PM
