Engine swap 1995 z28 350 to 406
Old Nov 3, 2015 | 08:04 PM
  #161
markoo91's Avatar
@95 camaro 406 did you ever consider running your exhaust out the side instead of going through the back?
Old Nov 6, 2015 | 11:01 AM
  #162
95 camaro 406's Avatar
yes but its a lot of work ,actually I was just kidding I like it the way it is ,its so loud the guy 7 houses down say he can hear it clear as if it was next door ,an to think when I add the full bores will be even louder ,I put single chamber magna flows an I blew the chamber on right side ,a bad spot weld wich rarely happens ,so to keep it safe full bore should be no issues ,it ticked me off after I spent $900.00 to install it the true duals that is ,then 1000 miles later a raspy noice from passegers side ,so while its got a life time warranty ,I need to take them off an order the full bores to kill 2 birds with one stone,for now I can live with it ,but one of the bugs to work out,i also have plans for 2 8x4 inch tips to ,there a heck of a lot cheaper then the 24 inch ones I had on the lt1 ,I would have put those back on but to long now selling those to pay for the others $69.00 I set for magna flow ,the 24s were $140 a set ,the thing I like about magna flow is they will last a life time if you take care of them
Old Jan 23, 2016 | 04:31 PM
  #163
old exhaust
this the one,like night an day from the other one ,what you think ? above
engine swap DSCN7121 95 camaro 406 - YouTube
was starving for air it shook bad
Old Jan 23, 2016 | 04:38 PM
  #164
Default with the tue duals an header
Originally Posted by craby
somehow your getting the wrong address, all i see is a question mark on yours. i had to use my special powers to look at the links address and go to the utube site and copy.
GEDC0505 - YouTube
like said it was starveing air in the other one these videos like night an day with sound ,performance ,let the puppies breath ,I am missing that sound right now big time,its getting ready for the shop soon an the front end repairs ,I desided I just got to do it ,an run them both this year the 3800 for long trips an this for around town ,AC waste of time now up hear in NE anyway
Old Apr 7, 2016 | 01:08 PM
  #165
when I finish the front end conversion ,I will put valvoline 10w40 conventional with zddp + an seafoam with each change ,wont change the k&N filter this time ,an will change the Anti freeze with orange allways ,an go about 3000 miles or the season ,I think 3 oil changes in the first 2000 miles is enough to get out any tiny frags with newer engines ,an tweak few things this summer .time to have the car back out on the road
Old Apr 8, 2016 | 08:39 AM
  #166
MKCoconuts's Avatar
Leave the SeaFoam out. Just my opinion. Oil is a delicate mixture of additives and detergents. Adding any thing to it means the things you actually need in the oil is now fighting for space with things you don't need.
If you're going to switch to Dex-Cool, I'd change it every few years, not every year. It's good for 5 years/150k miles and changing a year or so before the 5 will keep you on top of it. I like the green stuff though. Cheap and easy to get.
Old Apr 8, 2016 | 06:15 PM
  #167
HUmmm I wonder couse gorn had said it helps for gunk build up an stops it from happening ? mabey he just ment at storage or a few times a year ,couse I also been known to use stp oil treatment in between changes with zinc , changes yes dex cool is good I was only wanting to do it just a few times ,one thing that was not done was a good flush of the res,wich had some gunk in it ,I know should have pulled an cleaned it out ,it has been changed 2 times ,one more time then every few,car is starting to look like a car again
Old Apr 9, 2016 | 12:33 PM
  #168
MKCoconuts's Avatar
I'd use it may be before an oil change. But I'm not the type that would would run it constantly. I personally use a little ATF before changing the oil but that's me. Realistically though, if you change the oil on time and use a quality filter, you shouldn't have to worry about any gum, sludge, or varnish.
Old Apr 9, 2016 | 12:41 PM
  #169
yes only at oil changes is the plan thank you
Old Jun 29, 2016 | 02:32 PM
  #170
near 2 year update well warranty runs up in august ,an so far I got a good running engine trans too ,just leaned it down ,moved the fuel pump to the back ,fixed the wreck ,now I got shocks an inner tie rods upper ball joints time to give the suspension some tlc ,will post pics for the full resto mod if I can keep.it in one.piece ,takes time. I guess ,an I learned a lot from you guys hear at the forum could not have .done it well without you all I learned that slow is good .few tough.moments but you all put up with me thank you
