94 z28 s'charged 383 stroker build
scooch-thanks man i cant wait until i can drive it this spring!
socom- i was looking at turbo kits for it and i really like the sound and power of a turbo, but all my friends with their civics and mazdas and stuff have turbos and i really wanted to go with something a little less import. plus there is no boost lag with a supercharger. i feel like i can make the same top end power but better low end without the lag of a turbo. i am not totally dead set on a supercharger though. if i have the bottom end to support either then i can make my decision when the time comes next winter.
....but then i guess if i do go with the turbo setup then the thead title will be misleading lol....oh well
haha wow after reading that again i am not sure where i was going with that, but i never said they had the same efficiency, i know that turbos are more efficient because they use the exhaust from the manifolds, unless it is a rear mount system, to turn the turbine instead of using the power of the engine like a supercharger. like i said i havent made a final decision as to what i am using but sill leaning towards the supercharger
got to finally work on the car today, it was 60 outside which was really nice. i got the k-member unbolted from the body and started to lift the body off of it, disconnecting stuff as i go only have a few small things to disconnect and hopefully tomorrow will be able to roll the motor/trans/k-member out form under it.
it was a lot of work but it will be worth it
i got the motor/trans/k-member pulled today, had to lift the body pretty high to roll them out. unbolted the trans and started taking stuff off the motor, but cant really continue until i get a motor stand next week.
