2000 v-6 coversion to v-8
Old Feb 6, 2012 | 01:30 AM
H3llboy676's Avatar
Default 2000 v-6 coversion to v-8
i have never done this sort of thing to any car, but i thought it would be a good time to start because my v-6 motor blew and i wanted a v-8 for awhile, me and a friend took out the motor, the radiator (because previous owner put stop leak in it-caused motor failure), the automatic trans (stuck in drive), and thats all i have tooken off the car. i need help, i have searched all over trying to find some sort of step-by-step but cant find any, i would love some feedback on my project.
Old Feb 6, 2012 | 01:33 AM
Failed Devices's Avatar
buy a full donor car. it the only way really, otherwise (and even still) you are better off just getting a v8 car and not doing the swap at all
Old Feb 6, 2012 | 05:28 AM
In the V6 section there is a a V6 to V8 sticky that starts off as a joke but there are some links later in the post. Reality check is this swap is beynd most begineer capibilitys. As stated above your going to have to strip the car down to a shell and swap everything to do with the motor including the fuel system and the wiring harness all the way to the dash. The reason you can not find a step by step is because it would be a 400 page book.
If looking at the first page of this project does not scare you then your ready to start.
https://camaroforums.com/forum/93-02...kenbird-67185/
The doner car is the valuble part in this swap, That is why the above project is a good swap cause he has a known good driveline. Imagine doing all that work and when you fire up the motor there is a knock? Or after the car gets hot the oil pressure falls to zero. V6 bodies are cheap and common Low miles LS1 with trannies are neither cheap or common.
coopdc78
LS Series Tech
Jun 19, 2010 12:28 PM
Za33cK
Feb 24, 2010 09:42 PM
GESSMtr
Oct 20, 2009 06:52 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
camaroguyryan
Aug 28, 2006 12:16 AM
