2000 camaro v6 problem
Old Mar 23, 2016 | 04:24 PM
moorek's Avatar
Default 2000 camaro v6 problem
hi
I got this 2000 Camaro v6
167000 miles
having a problem
heres a link to the video
does it when idling but once I hit gas it stop doesn't always do it either
I need some help
thank you for your time and advice
Old Mar 24, 2016 | 07:06 AM
Do you have any codes? Surging like that can be cause by a lot of things. The computer is trying to adjust the RPMs some issue with the motor is causing the adjustment to be delayed so the computer "over reacts". It can be caused by anything from slop in the timing change to a lazy IAC motor and about 100 things in between. Hopefully you have some codes to guide you.
If there are no codes I would start with cleaning the IAC and Cleaning and check the EGR valve. Search youtube for How to videos.
coopdc78
LS Series Tech
Jun 19, 2010 12:28 PM
b_cantrell07
Mar 15, 2010 09:11 PM
dragatz
Mar 31, 2009 04:15 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
chevy_man
Jun 25, 2007 08:56 PM
