2000 camaro v6 problem
hi
I got this 2000 Camaro v6 167000 miles having a problem heres a link to the video does it when idling but once I hit gas it stop doesn't always do it either I need some help thank you for your time and advice |
Do you have any codes? Surging like that can be cause by a lot of things. The computer is trying to adjust the RPMs some issue with the motor is causing the adjustment to be delayed so the computer "over reacts". It can be caused by anything from slop in the timing change to a lazy IAC motor and about 100 things in between. Hopefully you have some codes to guide you.
If there are no codes I would start with cleaning the IAC and Cleaning and check the EGR valve. Search youtube for How to videos. |
