1999 v6 camaro wanting to upgrade to v8, ideas?
Old Jun 19, 2018 | 05:52 PM
ajwood2373's Avatar
Default 1999 v6 camaro wanting to upgrade to v8, ideas?
I want to see what the best path is with experienced swaps or very educated guess...ty
1999 chevy camaro existing 3.8l blown engine
Old Jun 19, 2018 | 06:04 PM
find a low mile series 3 3.8 and install it or sell it and find a v8 camaro. cost to change to v8 is more than its worth.
Old Jun 19, 2018 | 06:05 PM
Old Jun 19, 2018 | 06:07 PM
ajwood2373's Avatar
Default cost
well Im aware of that, but I like the frame, color, etc...any constructive ideas..lol
Old Jun 19, 2018 | 06:17 PM
ajwood2373's Avatar
Originally Posted by craby
ty...great info
Old Jun 19, 2018 | 07:04 PM
IMO you have 3 options.
1.)Convert the car to old school small block. You will invest twice what the what the finished car is worth. On your 99 just about everything is controlled by the body control module. Once you get rid of the PCM nothing will work and it will all need rewired, all gages will need replaces, power windows, lock, AC everything will need rewired.
https://camaroforums.com/forum/93-02...0-406-a-77465/
You can piece together a conversion kit. Keep in mind he spent 4K not including the price or the engine and transmission.
https://camaroforums.com/forum/93-02...v8-swap-78734/
The cheapest way would be to find a wrecked LS1 car and just switch the parts over. The only problem with that is a complete wrecked LS1 only sells for slightly less then a non wrecked one. There are people buying running and driving LS1 cars taking the engines/trans and parting out the rest because there are not enough wrecked ones around.
Socom got lucky and found a donor. Make sure you read the details.
https://camaroforums.com/forum/93-02...-thread-79265/
I have been a regular on this site for almost 10 years. 95% of the options one project that are started are never finish. Sure they may get the motor in and get it started maybe even get the car to move, but when faced with rewiring the entire car they just give up and the whole mess is sold off for parts. Keep in mind the option one project I linked was an older model without a body control model so he had about a 1/3 of the wiring you would have.
The budget friendly way to get into a V8 Camaro is to wait till a LS1 comes up with a blown motor. These are not what people are chasing. Then get a junk yard 6.0 or a newer 5.3 and drop that. You could be down the road for less then 3k and 1/10 the work of the conversion. You upgrade the cam on a decent 6.0 you could be close to 450 hp in a car that you can daily drive all day long if it tuned right.
shaione
Jul 31, 2012 07:28 PM
milkshakeman55
Apr 2, 2011 02:34 AM
ANC
Jul 26, 2009 03:13 PM
alexval2121
Jul 9, 2007 02:08 AM
aedude00678
May 31, 2006 01:14 AM
