Old Jun 6, 2016 | 11:15 AM
  #751
so how the heck does that happen,,, does the ball joint go in upside down,,, must be about equal length arms
Old Jun 6, 2016 | 11:58 AM
  #752
WIspartan1026's Avatar
May 2013 ROTM
here's the picture of it as it came out of the other car:
You can see that one side of the upper control arm is rounded, the other is straight. The rounded part is supposed to be toward the front, not the straight part. I just installed it the same way I received it.
Old Jun 6, 2016 | 03:08 PM
  #753
woh, seems like that would mess the caster all up
Old Jun 7, 2016 | 07:44 AM
  #754
May 2013 ROTM
yes, that is correct. I really don't know how they ran it on their car the way it is on mine now.
Old Jun 9, 2016 | 07:59 AM
  #755
May 2013 ROTM
*sigh* this car is a ****.
So I was hoping last night I could swap the upper control arms on the front. We had put the bolts in from the outside, so we would have to remove the top of the shock tower to get access. Well I undid all the bolts at the top of the shock tower, but there isn't enough range of motion in the new lower A-arms to give me room to pull the shocks down out of the holes. It's at the bottom its travel, but there is still compression in the spring.
So the best ideas my friend and I could come up with:
1. Loosen the k-member bolts, drop the k member enough to pull out the shocks
2. Use a spring compressor while it's still installed, compress the shock absorber by hand to remove it
Of course, this is going to be an issue as well if I ever replace the shocks for any reason. Any input?
Old Jun 9, 2016 | 08:56 AM
  #756
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I just use a screwdriver and pry the shocks out of my lower A arm seat. Its a bit of work but the best solution. You could just use a spring compressor too and compress the spring a bit to make it easier
Old Jun 9, 2016 | 09:09 AM
  #757
May 2013 ROTM
The fact that the spring is still under compression now makes me very, very leery of trying to pry the bottom part out. We unbolted it, but it's still wedged in there from the spring force.
Old Jun 9, 2016 | 09:51 AM
  #758
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
You can't loosen the coil overs any more to relieve the tension on the spring?
Old Jun 9, 2016 | 10:50 AM
  #759
May 2013 ROTM
I don't have coilovers, I have Bilsteins with Summit springs. They don't have many miles on them, so I figured I'd put those back in and sell the coilovers that came with everything. I removed the two bolts from the bottom and all the bolts up top, but it's still in compression.
Old Jun 9, 2016 | 12:00 PM
  #760
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Use a spring compressor then, it won't hurt anything.
