Old Jan 19, 2014 | 02:19 AM
  #641
you have one of them picks that look like a dentist would use it. they work pretty good for stuff like that seal
Old Jan 21, 2014 | 08:24 AM
  #642
WIspartan1026's Avatar
May 2013 ROTM
Almost there!
Got (I believe) the rest of the wiring taken care of yesterday, and installed the fans/radiator/AC condenser. One of the smaller hoses that goes from the radiator to the water pump disappeared somehow, so I'm gonna have to replace that and add coolant before starting it up. Also, I didn't add ATF to the torque converter prior to installing it. Should I add extra ATF for the trans to pump into the converter? Is there anything particular I need to do for this?
I also have a B&M Trans cooler that I plan to install. Here is how I intend to mount it:
B&M Cooler # 70298 install? - Page 2 - LS1TECH
Old Jan 21, 2014 | 11:41 AM
  #643
mine came with some plastic zip tie sorta things that went through the radiator and condenser. also had some rubber pads to go between the cooler and condenser.
Old Jan 21, 2014 | 01:39 PM
  #644
May 2013 ROTM
None of that stuff came with mine, I'm going to have to buy it separately. Is that how you have yours mounted?
Old Jan 21, 2014 | 04:56 PM
  #645
mine is mounted according to instructions, on the front of the condenser. got it from patc, this is what the kit looks like. Series 8000 Plate & Fin : 19 Row Series 8000 Plate & Fin Transmission Cooler Kit
Old Jan 23, 2014 | 08:04 AM
  #646
May 2013 ROTM
So my next question: tune. I'm considering getting a mail-order tune (probably pcmforless.com), if nothing else for a decent baseline. When I looked for stuff before, it was really tough to find anyone who still does LT1s, and the people I did find were like an hour away. So I'd get a mail-order tune, use that probably for this season, then maybe get a street tune a bit later down the road. Thoughts?
Old Jan 23, 2014 | 08:30 AM
  #647
i like solomon's tune better here LT1 PCM Tuning - Welcome!
Old Feb 8, 2014 | 02:41 PM
  #648
May 2013 ROTM
So I tried firing it up today. I can hear the fuel pump prime, and there is a loud "click," which I believe is the starter, but no crank. I know that there's any one of a thousand things that can be wrong the first time you try to start it once it's back together, but I have no idea where to start. Thoughts?
Old Feb 8, 2014 | 06:27 PM
  #649
connections on starter, battery and whatever else you can think of
Old Feb 8, 2014 | 10:54 PM
  #650
May 2013 ROTM
turned out to be a bad starter. Once I got it replaced, I managed to get it started!
