Removing door panels
Old Jul 1, 2005 | 11:55 AM
Z28princess's Avatar
Default Removing door panels
Hello all,
I am soundproofing the inside of my 98 Z28 and need to know how to remove the door panels. Can anyone help me? Thanks.
z28princess
Old Oct 12, 2005 | 08:58 PM
lottboy's Avatar
Default RE: Removing door panels
The door panel should have one or two screws located on the grip handle of the panel, if not, pop the door handle plate loose and pull it off, Pull up the door lock and electric window control panel and disconnect them from their harness's, in 98 they used plastic snappin pins all around the door panel there should be about 24 all the way around it. after the panel is off, disconnect the perimeter light on the panel. And there you go.
Old Feb 24, 2006 | 03:44 PM
elektrateq's Avatar
So I don't know much about Camaros as I'm working on my mom's car...
But when I was trying to remove the door panel (after unscrweing the screws), The door lock seems to be stuck and not able to let go of the plate with the controls on it to (assuming power connectors where disconnected). The door lock doesnt seem to fit through the hole in the plate in other words. I'm assuming the door lock stays with the door and the panel just pops off after the controls are removed. Can someone give me a little help?
btw, it's a 95 camaro.
Old Feb 5, 2008 | 09:55 PM
Fortee's Avatar
To remove the door panel, you will need to remove about 3 or 4 screws around your window controls/door handle. After that, you should be able to lift up on the panel and pull it right out.
Jim-Bob
Dec 31, 2012 05:06 AM
IdriveDSM08
Dec 4, 2011 11:24 AM
lilman316
Oct 2, 2009 07:06 PM
auburnspice
Feb 17, 2008 02:48 PM
L0tuS
Dec 7, 2005 12:29 PM
