Removing front door speaker panels
Old Sep 3, 2007 | 04:36 PM
auburnspice's Avatar
Default Removing front door speaker panels
Hey, I want to replace my front door speakers on my 2001 model but I can't figure out how to get the speaker panel/cover off. I can dislodged the four clips on the sides but don't know how to dislodge the top and bottom clips. Can someone tell me the secret to removing the panel/cover or will I have to remove the door panel to get to the speakers?
Thanks much!
Old Sep 3, 2007 | 04:56 PM
CamaroKid16's Avatar
Default RE: Removing front door speaker panels
i have a 94, but you have to remove the door panel on mine, and most other cars that know of.
Old Sep 3, 2007 | 07:55 PM
The Banks's Avatar
Its not hard to do, as a matter of fact I just got done taking mine off and putting it back on. Just take out the big screw under the handle, the little screw near the handle, and thethe other two big screws that are visible near the arm rest area. Be careful not to break any plastic clips.
Old Feb 5, 2008 | 09:56 PM
Fortee's Avatar
You need to take the door panel of. Unscrew the 4 screws as mentioned above, and lift up on the door panel and it should come right out. I think the speaker is held into the door frame by 3 bolts.
Old Feb 6, 2008 | 07:08 AM
bluovlh8er's Avatar
yea its pretty easy job though. the only pain is around the handel...
Old Feb 6, 2008 | 10:14 AM
LT1RUNNER's Avatar
And be carefull not to bend the metal shaft that operates the door lock. Haha! I said "shaft"!!
Old Feb 17, 2008 | 02:48 PM
sicked_wick's Avatar
damn that sucks...on my 96 RS the covers just pop offwiththe clips
IdriveDSM08
Dec 4, 2011 11:24 AM
lilman316
Oct 2, 2009 07:06 PM
Z28princess
Feb 5, 2008 09:55 PM
