opening the hatch problem
Old Apr 1, 2016 | 11:19 AM
jimf's Avatar
Default opening the hatch problem
With both the dash button and key fob, the hatch won't open without two tries, in the 2000 z28. Is there an adjustment to open it with one attempt?
Old Apr 1, 2016 | 07:25 PM
Everett#2390's Avatar
Welcome, Jim
Normal operation on my '00 & '02 SS's
Old Apr 1, 2016 | 09:27 PM
GaryDoug's Avatar
It's designed that way. Get a copy of the owner's manual here: http://shbox.com/pdf/2000camaro.pdf
Old Apr 3, 2016 | 06:58 PM
When I first got my 2000 I had to do it twice but I had to do a small lift on the hatch between the button presses. Press button twice it would not unlatch, Press button lift hatch, press button a second time then it would open. If that is the issue then a small adjustment on the rubber stops will fix the issue. 1/2 a turn fixed mine.
JoeClassic
Apr 23, 2009 08:24 PM
dcarter813
Aug 21, 2008 08:47 PM
Fogg
Nov 14, 2006 03:30 PM
