Fan won't work on climate controll
Old Feb 24, 2012 | 08:58 PM
RedSled99's Avatar
Default Fan won't work on climate controll
I have only had my 4th gen a couple of days. The fan was working this morning and now it is not. Is this a common problem?
Old Feb 24, 2012 | 09:11 PM
Which fan, radiator fan or HVAC fan?
Old Feb 24, 2012 | 09:52 PM
RedSled99's Avatar
Sorry about that. HVAC fan.
Old Feb 27, 2012 | 12:45 AM
There are severalthings to look at. Fuses, blower motor could have gone bad, blower speed switch, if blower only works on high speed check the resistors in the speed controller board.
Old Feb 27, 2012 | 10:13 AM
RedSled99's Avatar
I went through the car yesterday. The previous owner (insert dirty word here) wired into the fuse block (HVAC Fuse) to power an accessory. When they removed the accessory they just left the live wires exposed and they grounded out and blew the fuse. I removed the wiring and replaced the fuse. All good to go now. Thank you all for your help.
1976CamaroGuy
Jun 29, 2010 07:59 PM
RideTheSquirrel
Feb 10, 2009 02:05 PM
95camaro74
Nov 17, 2007 03:32 PM
Cpuma2427
Jan 9, 2007 04:23 PM
raymeg
Jan 19, 2006 11:27 AM
