Climate control panel bulbs - help
Old Jul 10, 2012 | 11:05 PM
Redcamaro1997's Avatar
Default Climate control panel bulbs - help
I have heard these little bulbs are nightmareish to get out, anyone have a surefire trick to get them out and what bulb number they are.....
Thanks
Old Jul 10, 2012 | 11:15 PM
BasicConcepts's Avatar
Technical User
there not hard to change at all pull the climate control panel there will be little circle bases that twist out than pull the bulb out of that and replace PN:74
Old Jul 11, 2012 | 07:39 AM
Up to the part of pulling the little bulb out, cannot get any grip to the top of the bulb to pull it out. Any tricks or ideas. Dont want to use pliers will surely break it.......fingers slip right off the top
Old Jul 11, 2012 | 08:16 AM
Got it!!!!!! Here is my trick, will save you some time and thinking ugly thoughts......
Take a small piece of duct tape and place over top of the bulb, use a pair of small pliers sideways (not traditional way because the tip of most pliers has a slick tip at the start which will not grip) they pull right out with little effort
Old Jul 11, 2012 | 03:08 PM
jkeaton's Avatar
^^ yeah that, only I was able to get mine out with my fingers with the duct tape on the bulb.
Dcapper81
Oct 27, 2012 12:47 AM
78 on my plate
Apr 2, 2012 05:34 PM
RideTheSquirrel
Feb 10, 2009 02:05 PM
95camaro74
Nov 17, 2007 03:32 PM
raymeg
Jan 19, 2006 11:27 AM
