1993-1996 LED Interior Swap ***How to***
Old May 14, 2012 | 01:46 PM
  #121
Chaotic94's Avatar
September 2011 ROTM
No problem bud. That's why people are scared of doing the led swap in 93-96 Camaros. It's an easy job tho. Any questions, let me know.
Old May 20, 2012 | 10:50 PM
  #122
DDRDiesel's Avatar
Well, finally got around to doing some pictures at night to get the full effect of the lights. Keep in mind, these pictures were taken with my DroidX. While the quality is usually very good (See my day photos in the "Post Pics of Your 4th Gen" thread), the quality at night drops significantly. Without further ado, here's my results:
Old May 20, 2012 | 11:38 PM
  #123
Chaotic94's Avatar
September 2011 ROTM
Looks good man!
Old Oct 29, 2013 | 04:58 PM
  #124
metalheadredd's Avatar
I have a question, but first wanted to say, thanks so much for this guide. I did a full LED swap so that I have the blue LED's everywhere. The only exception I have is the Fog light switch, and the window heater switch. These both still have the gunky greenish lights in them. Does anyone know what size bulbs, or what I need to do to switch these out?
Old Oct 29, 2013 | 05:02 PM
  #125
fbodyrs96's Avatar
theres no plug and play, have to be taken apart and solder in.
mine in red, I did mine back in 09 still lookin good.
Old Oct 29, 2013 | 05:34 PM
  #126
Chaotic94's Avatar
September 2011 ROTM
^ you're highly mistaken, friend. Mine was plug and play. They're 194 bulbs.
Old Oct 29, 2013 | 07:17 PM
  #127
Sophm's Avatar
I put a 5mm leds with a 560 ohm 1/2 watt resistor in the fog, defroster and 2nd gear start switch. Fog and defroster have 2 bulbs each one for backlight and one for on and off indication.
I did all 5mm leds in the cluster gauge back light by just soldering the lead to the board and left warning lights the standard bulb.
Mirror and rear dome light I got 6 leds that are 5mm in each. Made on a popsicle stick and works great.
Ac/heat controls, door lights and gear shifter. Are 5mm leds. Headlight switch 3mm led
Stock bose cd stereo replaced all bulbs with 3mm leds.
All cost about 10 dollars and time for some resistors and leds. Made it all myself and always can go back to stock and never looks touched.
Old Oct 29, 2013 | 08:32 PM
  #128
fbodyrs96's Avatar
For the fog light and defrost switch? How about the sgs and top up/down switch. I would really like to see how you got a 194 in there, when no one else has. Just like you mention that red can't be used on a camaro cluster, I've seen pretty much every color, it's the birds that can't use any other color without switching to a camaro cluster or aftermarket over lay
Old Oct 29, 2013 | 08:34 PM
  #129
Chaotic94's Avatar
September 2011 ROTM
I meant the gauges themselvrs. They're 194 plug and play
Old Oct 29, 2013 | 09:34 PM
  #130
Sophm's Avatar
This my help. Link
