1993-1996 LED Interior Swap ***How to***
Old Apr 9, 2012 | 04:04 PM
  #111
Chaotic94's Avatar
September 2011 ROTM
It's basically gravity pulling the needle around. The electric motors in the cluster level it out when you turn on the key. Like I said just plug it in before you put it all back together and make sure they lever out lol.
Old Apr 9, 2012 | 10:16 PM
  #112
DDRDiesel's Avatar
Looks like the needles are working, except the speedo. I used Android Speedometer for a rough estimate of my speed (Uses triangulation from GPS satellites), and it seems that the speed is wrong 90% of the time. I read somewhere that the speed will be displayed wrong if the rear end or the transmission has a wrong gear ratio. I figure it's worth mentioning that the person that owned the car before me swapped out the stock rear axle for one from a Z28, though I'm not sure exactly what that would do in terms of speed reading, considering the wheels are the same size...
Old Apr 9, 2012 | 10:30 PM
  #113
BudBrown's Avatar
November 2011 ROTM
Ride of the Month Director
isnt the speedometer driven from the trans?
Old Apr 9, 2012 | 10:32 PM
  #114
Chaotic94's Avatar
September 2011 ROTM
You need to check the rpo codes in he glove box and see what gear ratio your car came with. Then check the stamp on the rear end to see what gears are in your current rear end. You may want to start a new thread in the 4th gen section about rear end gears and surely someone will chime in to help you out.
  #115
Chaotic94's Avatar
September 2011 ROTM
Yes so if he has a "non" factory gear ratio, his speedo will be out of calibration.
Old Apr 19, 2012 | 11:38 AM
  #116
DDRDiesel's Avatar
Well, found a company that can help re-calibrate the Speedo, but I'm a bit iffy about using them. I'l include more info in my thread under the General section.
In the meantime; added the LEDs to the cluster and it looks SICK against the existing red under the dash (Area where your feet go, I can never find the proper name for it), and the newly-installed red LEDs in the rear view mirror (map lights). I'll get around to posting some pictures here for the LED sswap, and in my progress thread in the General section of the forum
Old Apr 19, 2012 | 01:30 PM
  #117
BudBrown's Avatar
November 2011 ROTM
Floorboard
Old May 14, 2012 | 11:34 AM
  #118
RedSled99's Avatar
Does anyone know what type the bulbs are. Superbright has direct replacements that do not need any soldering.
Here is the link to the bulbs. Just not sure which ones I would need to order.
Instrument Cluster and Gauge Backlights - Super Bright LEDs
Old May 14, 2012 | 11:56 AM
  #119
Chaotic94's Avatar
September 2011 ROTM
They don't offer our cars style of bulb. I have the part numbers provided at the top of the thread
Old May 14, 2012 | 12:28 PM
  #120
RedSled99's Avatar
I saw your part numbers. Was just curious. Thank you for answering.
