Window Wiring
Old Oct 24, 2010 | 02:06 PM
husker_camaro95's Avatar
Default Window Wiring
I have had issues with my passenger side window motor... but recently, the window decided to go down and not up. So i took the door apart and just put it back up manually. I have been told that i might just have a bad switch, which would make sense, do you know any way to test it? I have tried taking the one from the drivers side, but it still wont work... it only goes down. I even replaced the motor (under warranty from a previous purchase thank goodness). I have also heard that the window motors were incorrectly wired from the factory and to extend the life of the window motors, they should be rewired with the correct voltage running to them. Any input would be great. thanks
Old Oct 24, 2010 | 02:15 PM
see if any of this helps
Size:  46.8 KBName:  P7090002_1.jpg
Size:  66.6 KBName:  P7090004.jpg
Size:  54.2 KBName:  P7090006.jpg
mikebrow74
Mar 10, 2012 06:39 AM
mgg4591
82-92 V8 Tech
Jan 31, 2012 09:00 PM
TheGrizz
Mar 21, 2011 08:41 PM
Mrwickxo
Jul 19, 2010 07:44 PM
foxforcefive
Sep 9, 2008 05:03 AM
