'67 Power Window Wiring
Old Mar 21, 2011 | 08:41 PM
TheGrizz's Avatar
Default '67 Power Window Wiring
Hey First Gen-ers,
I was messing around with the wiring on my Camaro trying to figure out why the wiring in the driver side door wasn't getting the window up or down and I tracked the problem down to no power to the harness. There is this set of wires red, orange, and pink that run to a relay mounted behind the driver side kick panel. Problem is there is no power getting to the window. I have verified the window motor is good, and when I jumper a wire from the battery terminal on the fuse block to the red wire on the harness, the window works. Obviously, not the ideal way to get it to work. The question is, where is the power for that harness supposed to come from? The wiring has been an issue since the car came into my possession. Any help would be appreciated!
cornmuffin
Jul 24, 2014 10:22 AM
mgg4591
82-92 V8 Tech
Jan 31, 2012 09:00 PM
husker_camaro95
Oct 24, 2010 02:15 PM
foxforcefive
Sep 9, 2008 05:03 AM
