why wont the wheels work????
Old Feb 1, 2008 | 07:09 PM
Camaro Man 1999's Avatar
Default why wont the wheels work????
i have a set of weld draglites and i tried to put them on my car and they all rub the calipers. the front wheels rub bad but the back ones i can get away with 1/4 inch spaces which i put on and worked fine. but i then put 3/4 inch spacers on the front with longer studs and the wheels spin fine after the are tightened down when the car is jacked up in the front but when i lower the car down they wont turn the car spins the back tires before going forward if any one knows a solution to this let me know thank you.
Old Feb 2, 2008 | 12:20 AM
Default RE: why wont the wheels work????
i found out my problem thanks anyway my emergency brake cable was stuck LOL
Old Feb 2, 2008 | 08:34 AM
qmracer's Avatar
If that was the case why would you spin the rear tires when you tried to move, and why would the front tires not spin?
Old Feb 2, 2008 | 09:58 AM
bluovlh8er's Avatar
what the hell is going on here?
Old Feb 2, 2008 | 11:25 AM
JD1969's Avatar
You need to grind off a little bit of the caliper to make Welds work on our cars.
Old Feb 2, 2008 | 03:49 PM
Chappie99's Avatar
I had the same problem with my 99. I just grinded down the front calipers.
[IMG]local://upfiles/7064/E3C786DE97BD4ABD8E92E7E2BA6A7071.jpg[/IMG]
Old Feb 2, 2008 | 11:20 PM
yes thats exactly what i did i grinded off a little bit off each caliper unstead of using more spacers and making the wheels stick out to far thanks, and the back wheels would spin because the front ones were rubbing so bad they were locked up so in a sense it was like power braking.
Old Feb 2, 2008 | 11:24 PM
to anwsere your question gmracer the emergency cable got stuck at the same time i had put the weld wheels on the front but even with the emergency brake stuck, and the front wheels locked up it would still spin the back wheels unstead of the car moving forward LOL
Old Feb 3, 2008 | 02:25 AM
qmracer's Avatar
O i got ya so it was stuck just not as bad as the front wheels. I see now. I was just wondering how that worked out.
Old Feb 5, 2008 | 12:08 AM
yea it was lol but got it figured out now
Motocrossmom216
Apr 22, 2014 09:17 PM
karma187357
Feb 23, 2013 10:37 AM
mike6208
Jul 23, 2011 09:43 AM
66Fastback
Jul 15, 2008 07:34 PM
tyler2497
Jun 15, 2007 10:31 PM
