Who knows anything about wiring subwoofers.
Old Aug 28, 2011 | 01:10 AM
  #61
94ChevyCamaroV6's Avatar
Alright I am deciding between these three subs I will be buying two of what sub I buy because my box Is 2 tens. Between the two kicker cvr models Im not sure which one Is better they have the same wattage specs but one Is dual voice coil Idk If those are better then the single or If they break easier etc. Um If you have any subs that you would reccomend for the seventy or under price range then you can also If you can find me a amp for a nice price that would also be nice. I still need to find an amp and Im not sure If you are supposed to match the amp with the rms value of the subs or go a little bit higher. Also If anyone knows the difference between mono amps or the different classes that would be helpfull thanks.
Amazon.com: Kicker 10C104 Comp 10-Inch Subwoofer 4 DVC (Black): Electronics
Amazon.com: Kicker CompVR 07CVR104 10" subwoofer with dual 4-ohm voice coils: Electronics
Amazon.com: Kicker CompVR 07CVR104 10-Inch 4-Ohm DVC Subwoofer: Electronics
Old Aug 28, 2011 | 03:01 PM
  #62
Chaotic94's Avatar
September 2011 ROTM
Your amp's RMS should be 75%-100% of your sub's RMS.
Old Aug 28, 2011 | 03:12 PM
  #63
Alright Could you reccomend any of the subs above or a personal opinion I am thinking one of the two silver ones.
Old Aug 28, 2011 | 03:13 PM
  #64
By the way I already have a box that had two Jl tens In that but hopefully these subs wont be close to the drill holes of the Jl because then I might drill right through the middle of the Jl hole and have a two times bigger hole then I need.
Old Aug 28, 2011 | 03:25 PM
  #65
Chaotic94's Avatar
September 2011 ROTM
2nd link. A friend of mine has two of those in his firebird and they're hellatious!
Old Aug 28, 2011 | 04:05 PM
  #66
Alright then would you happen to know what amp he has then I was also wondering If I should get a four or eight guage wiring kit because I cant find a four.
greycon88
LS Series Tech
Sep 23, 2011 07:04 PM
JOEYCASHCAMARO
Mar 19, 2011 07:52 AM
Redeemed
Apr 14, 2009 11:32 AM
CamaroKid16
Aug 19, 2007 05:17 AM
91 RS
Apr 11, 2007 09:13 PM
