LS Series Tech 1998-2002
Two subwoofers hurting acceleration?
Old Sep 23, 2011 | 11:32 AM
greycon88's Avatar
Default Two subwoofers hurting acceleration?
I've got two 10's in a big sealed box in my trunk, takes up all the space and weighs about 60 pounds for the whole setup.
I read somewhere that if you want your car to have better accelation, you've gotta cut down on excess weight..
Do two subs weighing 60 pounds in the trunk hurt quarter mile time any?
My theory is that they could lower the suspension, provide the back wheels with more traction from the weight and actually make for better times!
Any thoughts on if I should remove the box for track days??
Old Sep 23, 2011 | 01:58 PM
All other things being equal lb/HP determines the acceleration rate.
Old Sep 23, 2011 | 03:31 PM
BasicConcepts's Avatar
Technical User
The rule of thumb is 100lbs as about a 1/10th of a second
Old Sep 23, 2011 | 06:40 PM
Failed Devices's Avatar
^or also 100# is like having another 10% hp
Old Sep 23, 2011 | 07:04 PM
Technical User
That too
JOEYCASHCAMARO
Mar 19, 2011 07:52 AM
Redeemed
Apr 14, 2009 11:32 AM
CamaroKid16
Aug 19, 2007 05:17 AM
91 RS
Apr 11, 2007 09:13 PM
Solace
Oct 20, 2006 09:44 PM
