What the fu-k! Crankshaft sensor went out again!
Old 11-12-2010 | 11:41 PM
AnalyzeFaith's Avatar
I looked at the cables and they do look pretty ****ed up. Could that have fried it or do I just need to fix them back up and it will hopefully start the car?
Old 11-13-2010 | 09:01 AM
Grandpaswagon's Avatar
Since you have identified some damaged wiring, I'd start there with repairing it or replacing it if it is readily available pig-tails.
After you get the wiring sorted out, then see what the car is doing and go from there. But I would spend a few days of quality time under the hood tracing out the wiring loom and repairing any damage that I found before anything else.
Slow, tedious and laborious work, but it is something that you can do in the parking lot.
Old 11-14-2010 | 09:45 PM
Even if I fix the wiring, will I still need to replace the CKS? Is it possible that it fried it?
Old 11-15-2010 | 11:38 AM
Massey's Avatar
Fix the wiring first then see how everything works. This sensor is mainly just a coil of wire that acts like a magnetic pickup and there is not much to fail inside of it.
Massey
Old 11-15-2010 | 05:49 PM
Without fixing the wiring, you are only throwing good parts into a bad situation. You will never get it all sorted out with wiring trouble.
Old 11-16-2010 | 02:22 PM
Still not working, suggestions?
Old 11-16-2010 | 02:30 PM
If you have repaired all of the cabling, now would be the time to see what codes are being set in the computer.
If you have not repaired all the cabling, then you need to take care of that first.
Old 11-16-2010 | 02:38 PM
The cables insulation was peeling off, I wrapped tape around it for now so the wires dont touch. There isnt any breaks or any snapped in half...
Old 11-16-2010 | 02:55 PM
Massey's Avatar
Good sounds like that could have been the cause here. Check for other places that there may be damage and let us know how stuff is working.
Massey
hawkins183
02-15-2012 11:50 AM
steveh3500
04-11-2010 03:31 AM
reloadx510
01-25-2010 07:49 PM
crw2008
07-21-2008 09:23 AM
97Cam3.8
07-10-2005 02:57 PM
Quick Reply: What the fu-k! Crankshaft sensor went out again!
