Viper Alarm Key Battery Replacemnt-easy? what can go wrong?
Old May 25, 2024 | 06:05 PM
CamBigCat's Avatar
Default Viper Alarm Key Battery Replacemnt-easy? what can go wrong?
Hello, I hope this thread finds you Camaro owners / operators / enthusiasts well,
Basically is this "project" idiot-proof"?
What I worry about is IN THE COURSE OF REPLACING THE BATTERIES WITH NEW ONES, messing up the programming or pushing the wrong button and engaging the Lock system which won't turn the car on, unless a Bypass switch which the Car Alarm Shop only knows where it is per a Tech at Viper who I spoke with yesterday
the bypass switch is a pencil eraser black head that's somewhere on the underside of the dashboard according to this viper tech
(Not a tech who is a viper, but a tech who works for viper LoL jk)
Background Info.
I purchased a Viper alarm system in about 2015.
The key alarm FOB requires 2 nickel size batteries and I had them replaced in 2022.
It (the FOB key) is currently SOOO worn out on mine--- that one can't even see the Lock Icon and Unlock Icons
(I don't drive or use the car often, therefore the car alarm key doesn't get much action)
I noticed some extra pressure needed to turn the alarm on and off, so I thought I'd buy the 2 batteries and as a Preemptive Strike proactively replace it soon
Info. from Viper's website
Quoted, in part....
You open not by using a screw but by using a flat head screw driver (super skinny, i opened it with a super thin, sharp putty knife) This will expose the circuit board and the battery. The battery on newer remotes is usually a CR2016, CR2032, etc, these batteries are about the size of a nickel and you will want to replace the battery once every 12 months to ensure proper and reliable operation. Some models such as the HD have a rechargeable battery that does not need to be replaced under normal use. (MY emphasis added) - cambigcat
Video on how to replace the batteries:
Thanks, in advance, have a smooth, happy, safe Memorial Day weekend 2024
Old May 25, 2024 | 07:04 PM
Thanks for the write up,got me to thinking I should probably put fresh batteries in several fobs I have,my daily work car,my Camaro and my Harley.
Old May 25, 2024 | 07:43 PM
CamBigCat's Avatar
You're welcome.
your handle reminds me of 1999 towards the end with the y2k worry
at the time I was watching a lot of the Drew Carey Show
CLEVELAND ROCKS! ... OHIO ! lol
Old May 25, 2024 | 07:45 PM
CamBigCat's Avatar
yea, this should be so easy to replace without doing irreversible damage
my posts are somewhat full of anxiety due to nerve damage
I like Phillipians 3:14 "I can do all things through Christ who Strengtheneth Me"
(even after health issues)
Old May 28, 2024 | 09:12 PM
Originally Posted by CamBigCat
You're welcome.
Wish this forum had a like button,I liked the Drew Carey show too.
My handle I've used on other forums,I bought a new Harley-Davidson Electra Glide in 2000 about the same time I first got internet.
Old May 30, 2024 | 06:28 AM
CamBigCat's Avatar
i liked the above, too
by the way, replaced the batteries in the alarm key fob and
The car batteries have to be put with the positive + mark inside the " metal clip" upwards on top facing you
careful, the circuits are exposed and everything inside looks delicate
The entire fob has to be gently closed and sealed by pushing down on it, too
It beeps easily and the blue light is brighter
Obviously if the car is parked far away, 1 has to get close to it, within signal distance
Old May 30, 2024 | 06:30 AM
CamBigCat's Avatar
just to clarify for newbies,
the nickle size batteries 2 of them, have 1 side in other words, that is clear with nothing just a blank silver and the other silver side with a + mark logo
that + mark side has to be up facing you, not downwards
graybeard47
Apr 17, 2014 09:48 AM
Chaotic94
Aug 11, 2012 06:43 PM
StealthChevy1500
Jun 14, 2012 10:40 PM
vinstay1027
LS Series Tech
Oct 11, 2009 10:26 PM
Nessy
Dec 2, 2008 10:59 PM
