ABS at low speed braking
Old May 29, 2024 | 09:50 AM
Wiggybaby's Avatar
Default ABS at low speed braking
1995 Z28
When coming to a normal stop, just before completely stopped , the ABS will activate real fast and low trac light comes on. The light goes back out once the car is stopped.
Brake lines are good condition
Brake fluid is fresh and system has been bled
Good tires
Excellent pads and rotors
Shocks and struts are new
Old May 29, 2024 | 08:59 PM
cwilt's Avatar
Sounds like you checked everything but the electrical connections. Might be a loose ground, corrosion in the electrical connectors or the speed sensors in the hubs. Might be time to break out that ohm meter.
Old May 31, 2024 | 07:26 AM
could be speed sensor at the wheels is not happy. also may be the wire harness from main harness to wheel sensor, common fail.
goodwrench67
Oct 24, 2012 06:40 PM
castorino
Mar 10, 2012 03:35 PM
shoeboy
Mar 9, 2010 07:56 AM
xxRONNIExx
Jun 15, 2009 10:10 PM
RyanBumZ28
Jun 1, 2007 08:42 PM
