Vibrations after engine swap 96 3.8L A4
Old Nov 21, 2020 | 07:17 PM
Chantz Webb's Avatar
Default Vibrations after engine swap 96 3.8L A4
So swapped in a used engine(from a 2000 camaro) with new motor mounts, after i got everything hooked up, no leaks etc it vibrates when idle/ stopped, basically goes away as your driving. No real difference between “in gear” neutral or park. I’m suspecting transmission mount, maybe driveline u joints, but would like some opinions on this before I go spend more money:-)
thanks in advance!
Old Nov 22, 2020 | 08:13 AM
double, tripple check your plug wires to make sure you got them in the right places, easy to get crossed.
Old Nov 22, 2020 | 10:57 AM
will do!, if that’s not the culprit, do I check coil packs? Plugs are new coils and wires are a lil old. But if ya have any other ideas let me know
Old Nov 22, 2020 | 04:50 PM
pick up a spark checker at the parts store, that should let you know if you have a weak coil. if the wires are old it would be a good idea to replace. once they get past 5 years its getting about time to start looking at them. I wait for a dark night close up the garage if I have to to get it really dark, open the hood and start it and have a look in the area of the wires and plugs, shut it off right away if in enclosed area, open it up. if you getting a light show they is bad. first time I tried that after thinking of it I was surprised to see all my wires was lighting up.
Old Nov 22, 2020 | 06:09 PM
I may still do that but, long story short, this is my sons car-(I’ve got a Z28) so he’s done a majority of the work with guidance from me...well he never bolted down the trans mount...now that’s done basically all vibrations are gone. But I may still check out the wires/coils to play it safe
Chantz Webb
Nov 2, 2020 07:11 AM
ztwentyate
Jan 20, 2016 05:14 AM
aron_ft
May 31, 2012 02:30 PM
TheSolution_420
Feb 6, 2012 08:16 PM
shrews61
Sep 16, 2010 11:48 AM
