Camaro ss 02 stuck in second gear
Old Nov 25, 2020 | 04:09 PM
Diana Carlos Barron's Avatar
Default Camaro ss 02 stuck in second gear
I have a 02 camaro ss stuck in second gear automatic i got codes p 0332 P0327 and a bad MAF would this cause transmission to not get out of second gear . Hadvtransmission rebuilt less than 1,000 miles on it
Old Nov 25, 2020 | 10:43 PM
No, there is no engine code that would cause a trans to stick in second gear. If you pull the trans pan and its clean then you are talking and electrical or a valve stuck on the valve body. .
Old Nov 26, 2020 | 05:28 PM
HenryC's Avatar
Hopefully the rebuild had a warranty with it, I'd say bring it back to whoever rebuilt it
Old Nov 27, 2020 | 03:42 PM
are you saying the shifter will not let you shift out of second or no matter what even when put to park it stays in second. explain better what is happening.
ctlow
2010+ Transmission
Jul 4, 2013 06:01 AM
brownr72
Aug 11, 2010 04:06 PM
96CamaroZ28
Jul 10, 2010 04:15 PM
turboz28
Jan 7, 2009 07:17 PM
Hisss04Cobra
VS
56
Apr 3, 2007 03:22 PM
