Intake manifold swap?
Old Oct 31, 2020 | 10:10 AM
Chantz Webb's Avatar
Default Intake manifold swap?
I’m swapping engines, I’m trying to put a 2000 3.8l series 2 into a 96. Can I interchange the upper intake manifold from the 96 engine to the 2000 engine? I read the sticky on swapping engines but all it said was there’s a change to accommodate the TBW but the 96 is TBC, any help or information regarding this swap would be greatly appreciated
Old Oct 31, 2020 | 11:18 AM
pm gorn to make sure, I am pretty sure they are. again what did the 2000 come out of?
Old Oct 31, 2020 | 11:38 AM
the 2000 came out of a camaro as well
kinda new to the site...how can I PM him?
Old Oct 31, 2020 | 01:05 PM
HenryC's Avatar
https://camaroforums.com/forum/members/gorn-10889/
Click social profiles then send private message to gorn.
Old Oct 31, 2020 | 01:09 PM
thanks!!
Old Nov 2, 2020 | 07:11 AM
then it should be fine. change the lower intake gasket no matter what, that is a common fail point. if antifreeze is not changed for long time, it can eat the lower gasket causing coolant to get into oil which once heated after mixing with oil turns to acid that eats bearings.
Camaro Tuner
Aug 9, 2016 08:46 PM
riverman95-99
Feb 12, 2012 01:59 PM
96 3.8L Texas
Oct 22, 2010 07:32 PM
typappy
Sep 27, 2009 03:56 PM
raymose
Mar 24, 2008 08:16 PM
