99-motor swap
Old Feb 11, 2012 | 07:52 PM
riverman95-99's Avatar
Default 99-motor swap
When swaping a 3800 v-6 with electonic throttle body with one with a cable do you need to change the upper & lower intake ? The other 3800 is out of a 98 firebird.
Old Feb 11, 2012 | 08:01 PM
change them both i think the 99 has a better intake and make sure to change all the gaskets.
Old Feb 12, 2012 | 08:17 AM
Craby you had me scared cause I resused my 96 lower intake, I just double checked the lower intake is the same GM part number 24505829, 95-02
Resealing the intake is a good idea since it is a common failure point.
Old Feb 12, 2012 | 01:59 PM
osduck5's Avatar
And dont forget to replace the plastic L shaped water hose!!
amsteff
Nov 14, 2011 11:14 AM
sandvipr
Apr 25, 2011 12:03 PM
mregulater
82-92 V8 Tech
Mar 10, 2009 11:47 AM
dmolaver15
82-92 V8 Tech
Dec 20, 2008 08:46 PM
Camroman250
Apr 30, 2006 12:17 PM
