Usually get a weird smell from exhuast
Old Dec 18, 2013 | 08:38 PM
blackbeauty1995's Avatar
Default Usually get a weird smell from exhuast
Alright so i noticed when I bought the car last week while idiling it smelled a bit like raw burning fuel kinda coming from exhaust area but no smoke or anything. So I just wanted to ask what it could be because I know if it was a blown head gasket then there would be smoke coming out, or hot motor temps and lack of power usually which I have none of the symptoms, so what could be causing this as I noticed it like 2-3 times already whenever just idiling!
Old Dec 18, 2013 | 08:49 PM
MKCoconuts's Avatar
Check plugs. Might be running way rich.
Old Dec 18, 2013 | 09:22 PM
^^^ and have it scanned for trouble codes. let us know what code numbers come up if any. test fuel pressure, you can rent or borrow a test gauge at most parts stores. low or high pressure can cause rich condition. check 02 sensors for fouling, failing 02 sensor can give a false reading if fouled. usually a lean reading that causes the computer to add more fuel. which fouls it more making the reading even more lean when in fact its a rich condition. anyways theres a few things to look at.
Old Dec 19, 2013 | 09:45 PM
Alright well I already have a fuel pressure gauge so ill check the pressure tomorrow. Im guessing the shrader valve is on the fuel rails and pressure with car off should be like 40psi rite.... I forgot
Old Dec 20, 2013 | 04:23 AM
aniyishay
Jul 27, 2011 11:42 AM
RZ28
Jul 18, 2008 10:53 PM
bens99camaro
May 30, 2008 03:11 AM
daniel96
Nov 30, 2006 11:28 PM
CaMaRoDuDe
Sep 24, 2006 10:58 AM
