Turn signal and brake problem
Old Nov 22, 2018 | 04:23 PM
Charlesriddle's Avatar
Default Turn signal and brake problem
Hello, i just bought a 95 camaro with a v6. Im having trouble, trouble shooting a problem with my tail lights. My right turn signal and brake light work ffine. My left side, when i turn my running lights on all the lights come on. When i turn my turn signal on, the front one comes on and the light on the dash comes on but it doesnt flash, and the back one doesnt come on at all. When i hit my nrakes the right one works but the left doesnt. I have changed the bulbs and checked the fuses nut still no luck. Does anyone jave any suggestions?
Old Nov 23, 2018 | 06:08 AM
get the volt meter out and see if its getting power to the socket.
Old Nov 23, 2018 | 10:45 AM
peterpar's Avatar
Craby is right, you need to first determine if the there is power and a ground at the turn signal. Use a meter or test light and check between the yellow and black wires at the socket while the turn signal switch is on. If no power is found, check again but this time between the yellow wire and a metal body ground. If still no power, the problem is most likely a broken wire between the turn signal switch and rear light or the contacts in the turn signal switch are bad and the switch will have to be replaced. To check the yellow wire for being broken, pull apart the connector of the switch under the column. Find the yellow wire in the connector half going out to the lights and use a meter set on ohms to check if you have continuity between a body ground and the yellow wire. If you have continuity, remove the bulb from the rear light and check again. No continuity this time would indicate the wire is good and the problem is probably in the switch. I've attached a schematic for the lights that may help you follow how the circuit should work.
Vidkid
Dec 3, 2019 03:27 PM
kojack
Dec 4, 2016 02:18 PM
abestoy
Aug 2, 2009 12:47 AM
80Mike
Sep 25, 2008 04:05 PM
chrisb6560
Nov 16, 2006 07:09 PM
