turbo charge LS1
#34
RE: turbo charge LS1
Man, Specter you've gotta change your sig back, I'm getting all confused as to who's posting here, I don't want to have to read names!
Importmd, I was simply trying to make a point and usually using the extremes is the easiest way to illustrate that. I'll make the point even clearer:
Track Only: Go for a S/C.
Street/Strip: Go for a good Turbo setup.
In either case the motor needs to be rebuilt to low compression as has been stated multiple times to get any true gains out of the forced induction.
#35
see, now that was better. Had a little Q n A with the new guy toss around a little "IMO's" give some useful advice. keep it simple, keep the dump ones away, help people out, gain new members.
#36
thats kinda what was happening the whole time [&:]
Im sorry you feel the need to police the sections, but I personally didnt see any unnecessary tangents in this thread until right at the end here.
to break it down:
I want to turbo
i dont think you should turbo
turbo mis information
correcting information
discussion on differences of systems
if you really want to turbo then....
in that order
in this forum we get a "should i supercharge or tubro my car" thread about once a week at least. 99% of them never happen anyways because the people dont know what they are getting into. so the most appropriate and helpful way to handle these threads is to first make sure the OP understands the extensiveness of the project. Once the OP understands that and is still willing to proceed then we can talk about the how
to break it down:
I want to turbo
in that order
#38
I agree with you man...https://camaroforums.com/m_160635/mp.../tm.htm#160635
ORIGINAL: importmd
im sorry if you think im policing, somedays its like a day care around here.
#39
OK guys listen up.
Boost is boost. 6 psi on a blower is the same as 6 psi on a turbo (basicly). A centrifical blower is pretty much a belt drivin turbo, so it will not reach peak boost untill higher RPMs, roots superchargers have good off idle torque, but have heat issues and tougher to cool. Finally...Top Fuel cars run blowers because the RULES IN THE CLASS DO NOT ALLOW TURBOS!
#40
ORIGINAL: JD1969
OK guys listen up.
OK guys listen up.
