Trans Removel
Old Nov 28, 2008 | 09:28 PM
Default Trans Removel
I have my whole driveline pulled on my 96 V6 5 speed. I am trying to get the transmission apart from the engine. I have the cover off and all the bolts I can see off I ampulling the trans and bell housing all at once. Its about 3/4" apart from the engineand it just stops, It will not come any farther. At that distance it clears the dowels and wiggles real easy. Any clues?
I read thru this and I can not see what I am missing. No mention of a pivot bolt or removing the slave.
http://forum.camarov6.com/showthread.php?t=92218
Old Nov 29, 2008 | 09:02 AM
importmd's Avatar
Default RE: Trans Removel
i dont know if they are the same setup as the t56 but i know on mine i had to unblot the clutch fork.
Old Nov 29, 2008 | 06:29 PM
No bolt on this one. Just me being tired. I tried it tonight and it came right apart. Seems there was a build up of dust/rust/crude on the input shaft on the back side of the clutch plate. This made it tuff for the input shaft to slide thru the clutch.
All is well.
Old Nov 29, 2008 | 07:13 PM
rondavis's Avatar
when i did my t56 it took alot to get it back in but if you seperate the bell houseing and trans before install it will be easier to get back together
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
surfhppy
Jun 25, 2011 04:18 PM
94z28chevy
Jun 30, 2010 07:43 AM
flemingshane
LS Series Tech
Aug 13, 2009 06:13 AM
