Tranny Problem!!!
Old Oct 16, 2007 | 01:00 PM
graffiti oner's Avatar
Default Tranny Problem!!!
Yet I have another problem with my car...I drove a bit in the morning today and the car was fine until now, an hour later from parking it, this loud clunking noise came out of nowhere. I referred to my manuel and it said to check the driveshafts connections because it clunks under initial load (when I first step on the gas after stopping). I checked underneath it and there is this loose bolt that I cant get back in because I think it's not lining up right. And it looks like the driveshaft slid out a bit. Refer to pic at....msnusers.com/CamaroSS, the bolt is facing the passenger side.[/align]
Old Oct 16, 2007 | 06:58 PM
deltav's Avatar
Default RE: Tranny Problem!!!
The same thing happened to me when I reinstalled my tranny. It was my torque arm though, soI had to really tighten down all the bolts to torque specs cuz I didn't do that initially. It does take a little work to get it aligned. I had to have the car lifted a certain way to get the torque arm close to alignment(my car has lowering springs in the front only), then I adjusted the rest.
Oh, and my driveshaft looks like that too.
Old Oct 16, 2007 | 10:07 PM
genvoodoo's Avatar
Almost looks like something was taken off the tranny and not put back on.
Old Oct 17, 2007 | 01:22 AM
I got it, turns out that the torque arm slipped out because the top bolt for the drivers side trans mount bracket stripped and fell out. So the the torque arm fell out also and I guess the space between the driveshaft and tranny made it knock and clunk at the initial load. Thank god the tranny wasn't bad.
Old Oct 18, 2007 | 07:23 PM
deltav's Avatar
Glad you found out it was before you started taking things apart!When I put it back together, it was a little hard to line up. I did put a polyurethane torque arm bushing cuz my stock one broke on pieces when I unbolted the torque arm! Might as well put one on since you're there.
first_one
Aug 12, 2012 08:49 PM
Nmead91
LS Series Tech
Apr 8, 2010 08:45 PM
dodge destroyer
Mar 25, 2008 08:16 PM
wolfe 21
82-92 V8 Tech
Jul 9, 2007 09:16 PM
Aram
Feb 11, 2007 09:05 PM
