LT1/LT4 Tech 1993-1997
I need help on my 94 z28. Tranny problem
Old Mar 24, 2008 | 07:05 PM
dodge destroyer's Avatar
Default I need help on my 94 z28. Tranny problem
I bout the car saturday and took it for 40 min. ride today. And I have two problems with the car. And they are as follows.
Tranny problem: On the way into town it shifted fine but when i reached town it wouldent shift into snd unless i let off gas around 23 mph.
It was rebuilt 100 miles before by a guy that works on cadillacs.
Motor over heating: The car overheated, And the fans wouldent turn on untill then temp. reached the red zone. I thought it might be a stuck thermastat but dont know.
Any help that I can get would be appreciated. Thanks
Old Mar 24, 2008 | 07:31 PM
Saint_Ali's Avatar
Default RE: I need help on my 94 z28.
is the tranny auto or manual ?
as for the over heating, yes one it could be the thermostat, if you wanted to check if it was working you can always pull it out, and put it in a pot of boiling water and see if it opens at 180, it could be old coolant
and if the fans arent coming on, check the fuses, and see if the wires are connected under the hood on the left side of the car, the connecting tips could be corroded
there are two fans, a high and a low, the low should come on anytime the a/c is activated and when the car reaches about 200 degrees
Old Mar 24, 2008 | 07:51 PM
It is a rebuilt 4l60e.
I checked the fuse and its good. Not sure anout wires and tips.
The guy had a tablet that tells what all her has done to it. as follows
And the motor has 7,000 miles. well over due.
The car has 136,600
Miles item
100,600 coolant, water pump, distributer cap, fuel pump, plugs & wires
123,362 o2 sensers
Old Mar 24, 2008 | 07:53 PM
Saint_Ali's Avatar
yeah i would definately drain the coolant and put new coolant in, also the relay for the fan may not be functioning correctly
Old Mar 24, 2008 | 08:03 PM
How about the trains? When i get around 2200 I let off of the gas and it shifts to 2nd. I had it in 2nd and floored it downshifted to first but wouldent shift back to second.
Old Mar 24, 2008 | 08:13 PM
I messed up on last post. the MOTOR OIL hasent been changed in 7,000 miles.
Drivetrain has 136,000.
As soon as i figure out the problem I'm going to change the oil.
Old Mar 24, 2008 | 09:24 PM
Saint_Ali's Avatar
well i suggest doing all the fluids and by the way it doesnt do anything manually shifting a automatic, especially since yours is electronic, the computer will automatically shift it to the next higher or lower gear
Old Mar 24, 2008 | 09:38 PM
I wasent manually shifting it.
I had to get it up to 2200 rpms and let off of gas and it would shift into 2nd on its own, then i floored it when it was in 2nd and it downshifted into 1st gear and it redlined, it wouldent shift to 2nd so i let off and drove slow on the way home. It shifted fine n the way into town.
Old Mar 25, 2008 | 05:31 PM
Saint_Ali's Avatar
yeah i would change the fluid first and see if that helps, dont forget the filter!
otherwise it could be something with the linkage in the tranny or maybe the clutch ?
Old Mar 25, 2008 | 06:19 PM
Common reasons for your problem:
Contaminated fluid clogging passages in the valve body
1-2 shift valave sticking
Valve body gasket out of position
Shift solenoid sticking or damaged, or bad electrical connection
2-4 Shift servo assembly passage restricted
4 th servo piston in backwards
2-4 band damaged
If changing the fluid does not help, the above items will have to be looked at.
