4 spd tranny problem
Old May 12, 2012 | 04:01 PM
first_one's Avatar
Default 4 spd tranny problem
I have a 68 camaro with a 4 spd muncie. It just locked into a gear (thinking 1st). Was pulling it out of the garage up onto my driveway. The gear shifter is over where 3 to 4 is, and seems to be in the neutral position. I have 1-1.5 in up and down play, very little side to side movement. Clutch works fine. Not too sure where I start.
Any ideas?
Old May 12, 2012 | 04:36 PM
Best thing to do is get under the car and have a buddy work the shifter while you look at what is or isn't moving.
A shift rod could have dropped loose, or got lodged. Or it could be the shifter itself jammed or some foreign object stuck/wedged in there.
Old Aug 12, 2012 | 08:49 PM
82ndAirborne96's Avatar
Default Did u get the issue fixed?
This just happen to me this morning.. I'm trying to figure out what the issues is.
Nmead91
LS Series Tech
Apr 8, 2010 08:45 PM
dodge destroyer
Mar 25, 2008 08:16 PM
wolfe 21
82-92 V8 Tech
Jul 9, 2007 09:16 PM
Aram
Feb 11, 2007 09:05 PM
fatass91
Jun 28, 2006 01:03 PM
