Tire Size Questions
Old Nov 26, 2011 | 08:00 PM
Not sure if it will help but the numbers mean something. 245/50/16
First number 245 MM wide tread (or 9.65")
Second number is a ratio of width to side wall height. Since the above is 50 or 50% that would be 245 X 50%=122.5 MM (4.82" tall side wall).
You can use above to calulate the diameter of the tire 16+4.82+4.82= 25.64 Dia. Compare that to your current setup to check to see how far the computer will be off. As you go wider you want a lower percentage of side wall to keep your diameter close so you do not need to update your computer.
Old Nov 27, 2011 | 09:08 PM
vanquishfist's Avatar
I was thinking about this too a while back and was using the same calculations to figure how close I could get to the same height with a wider tire.
Old Nov 30, 2011 | 11:50 PM
libertyforall1776's Avatar
My current tires are the 235/55/16...
Old Dec 1, 2011 | 01:05 AM
Either 245/50 or 255/50 would make your speedometer show a higher than actual speed. 255 would be closer to the same diameter as the 235/55s though.
Old Dec 7, 2011 | 07:31 PM
Wink
Well, I think you have to qualify that, since with a larger contact patch you get worse traction on snow, ice, etc. My application here is all season in the midwest, so I am sure your comment didn't apply to this...
Dry may be fine, though.
Local tire shop said the difference between V6 stock and the Z28 size ends up being ~ 1.3 something Mph difference, so the speedo shows you're going faster than you are...
Originally Posted by 3800camaro
245/50/16 is what I have. They are awesome. Biggest size you can go is 255 then you need wider rims.
Old Dec 12, 2011 | 07:36 PM
So there is a nationwide backorder on the BF Goodrich Z rated tires till January, so I went with Michelin Pilot Sport A/S Plus tires Z/W rated, 245/50/16. Much better.
FYI, those wondering about tire sizes and speedometer calculations like Gorn was talking about, there is a free calculator HERE:
Tire Dimensions Made Simple - Discount Tire
Oh, I also learned my chrome wheels are peeling under where the tire sits too, so air leaks are likely -- damn midwest salt! So looks like I need to start hunting new wheels as well...
Old Dec 15, 2011 | 10:32 PM
I compared 235/55/16 to 245/50/16 on the calculator, and it shows if your speedometer reads 100 you're actually going 97.97. So to correctly figure your mileage you'd have to subtract 2.03 miles for every hundred, or .0203 for every mile correct?
jeffchairs
May 17, 2014 02:24 PM
pcarollo
Aug 30, 2011 11:51 PM
68SS/RS
Aug 22, 2010 05:28 PM
82Camaro
Aug 18, 2010 08:51 AM
ddroode87
May 18, 2010 08:45 AM
