tire size
Old May 16, 2014 | 10:25 AM
jeffchairs's Avatar
Default tire size
I have a 1996 z-28 I am trying to straiten out something the old owner did.it has y2k corvette wheels 245 45 17 on the front and 285 40 18 's on the
Back.I can see were they rubbed.he put weird springs and air shocks on it.my question is will a smaller tire clear with
Stock springs and shocks?I want to figure it out before I try to get it inspected.
Old May 16, 2014 | 11:12 AM
jeffchairs's Avatar
Any help is appreated
Old May 16, 2014 | 12:02 PM
where are they rubbing, may have to trim the bump stops, roll the fender wells or take a hammer to adjust some steel.
Old May 16, 2014 | 04:32 PM
jeffchairs's Avatar
It is rubbing on the inside of rear fenders.wondered if they were inset too much or if it was tire
Last edited by jeffchairs; May 16, 2014 at 04:33 PM. Reason: Just wanted to add info
Old May 16, 2014 | 05:06 PM
might have to get the hammer out and make some room. have a look here Wheel & Tire FAQ - General Topics - CamaroZ28.Com Message Board they are 17s but if its the same spot you should be ok. is the car lowered, sounds like maybe.
Old May 16, 2014 | 08:36 PM
jeffchairs's Avatar
Thank you I am going to let the air out of the shocks and c if they clear.if so I guess I am gonna order the stock springs and shocks.he said it had cut springs at one point .it looks like he might have actually already hammered out the inner fenders in the back.thanks again
Old May 17, 2014 | 02:24 PM
if its on the inside you may be able to add a 1/4 inch spacer and move the tire out. depending on the offset it may be they set to far in. have a look at strano's site Strano Performance Parts - Parts Search he has some nice stuff and if you order from him he will give good advise. may know exactly what is needed.
Davila2000maroRS
Apr 27, 2011 05:13 PM
68SS/RS
Aug 22, 2010 05:28 PM
kstoll99
Sep 27, 2009 11:13 AM
bd92rs
Aug 7, 2009 09:04 PM
DUB C
Feb 11, 2008 07:03 PM
