Tire Size Questions
Old Nov 26, 2011 | 03:22 PM
libertyforall1776's Avatar
Question Tire Size Questions
So I need 2 new front tires for my RS, and am considering 245/50/16 tires on my stock rims, but this size is for the Z28 -- will there be any issues?
It looks like going with this size I can get a ZR speed-rated tire which should be better for handling due to the stiffer sidewalls, regardless of the RS' top speed.
So does that size above sound ok on these stock rims, despite the stock size is normally 235/55/16?
TIA!
Last edited by libertyforall1776; Dec 7, 2011 at 07:33 PM. Reason: been told there isn't a width difference on the rims between base and Z28...
Old Nov 26, 2011 | 03:30 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Yeah there shouldnt be any issue with fitment, But if you want better cornering go with a smaller sidewall (maybe a 40 or a 45). I think large sidewalls on camaros look weird.
Old Nov 26, 2011 | 03:54 PM
^ Searching Tirerack.com there is just nothing in those sidewalls with that 245 & 16" for all-season tires...
Old Nov 26, 2011 | 04:01 PM
245 50 16s will fit fine on an 8 inch rim. speedo should be close to the same.
Old Nov 26, 2011 | 04:08 PM
RFxCamaro's Avatar
Yea I have 245/50/16 and no problem with fitment
Old Nov 26, 2011 | 04:20 PM
Thanks for the inputs all. So I still have good tread on the rear -- any issues having 245/50/16 in front, and 235/55/16 in back (could be vice versa for that matter)? I would hate to waste useable tires...
Old Nov 26, 2011 | 05:23 PM
would look and handle better with the thinner tires on front.
Old Nov 26, 2011 | 06:11 PM
^ Meaning the shorter sidewall height tires, correct?
Old Nov 26, 2011 | 07:19 PM
3800camaro's Avatar
245/50/16 is what I have. They are awesome. Biggest size you can go is 255 then you need wider rims.
Old Nov 26, 2011 | 07:44 PM
the wider tire should be used in the back. at least thats what i would do. the hight difference is not much. 1/3 inch.
