Is there a way to undo cooling fan turn on speed
Old Nov 25, 2008 | 05:00 PM
hogdad's Avatar
Default Is there a way to undo cooling fan turn on speed
Hi all, Just picked up a 96 Z28 6 speed and after changing the ECM colling temp sensor and the gauge sending unit and the thermostat and radiator cap I've come to the conclusion that the previous owner must have set the fan turn on speed with a hypertech. the car runs up to about 180-185 or so then the fans kick on and stay on unless I drive the car. The car runs too cool for me andI get lousy heat. I don't want to spend 300 on a hypertech since I need a clutch tires and the rear axle needs something in it too.
Old Nov 25, 2008 | 05:27 PM
Saint_Ali's Avatar
Default RE: Is there a way to undo cooling fan turn on speed
thats a fine temp, factory they turn at about 210, as long as its between 180-195 its fine, thats the temperature of an engines happy zone
Old Nov 26, 2008 | 02:39 PM
LT1RUNNER's Avatar
Yea, camaro heaters suck. When mine worked it got warm at best. Luckly I live in the Valley of the Sun so we don't get very cold out here.
Old Nov 26, 2008 | 02:48 PM
02StanGT's Avatar
If the PCM was programmed by a Hypertech, and the tune is still in there, you need to either get the PCM reflashed by someone, or find the Hypertech that tuned the car. Getting a different Hypertech won't help if I remember right.
den510
Sep 16, 2013 02:07 AM
MaVeN
Mar 12, 2012 09:50 PM
rext
67-69 V8 Tech
Sep 23, 2011 11:49 AM
