OEM Y-Pipe 2002
all the ones ive seen are catted y-pipes
Now I am confused. Based on that site info the Y-pipe fits 95-2002. If that is the case then my 96 Y-pipe will work with the2002 manifolds. That is good news if its true. At almost $300 for the stock Y-pipe its not worth it. I can buy coated headers and y-pipe aftermarket for $390
http://www.lmperformance.com/19318/13.html
I'm bout 99.9% sure the 02 manifolds will fit your older y-pipe. I would be 100% sure had I seen this first hand from someone. I have just read that people have swapped them out.
